SteveWhite Dual Fuel Pumps
Baton Rouge
LA
2016 Challenger HC
Anyone have any experience with this set up?
white1
Prairieville
LA
2020 hellcat charger widebody
I do not, however we have installed a few of Tapped performance pump kits in scat packs. I have the Tapped dual pump setup coming for my hellcat.
I noticed your in Baton Rouge as well. Hello neighbor
W
Baton Rouge
LA
2016 Challenger HC
Howdy neighbor! I will either be going with a Tapped setup, or steve white claims they're making an updated version of their current dual pump setup that will be close to Tapped's while using the oem basket
white1
Prairieville
LA
I haven't looked into the SW pumps yet, but I can say the quality for the single pump setups at least from Tapped are top notch
Metairie
LA
19 Charger HC
How is the install on the Tapped kits? Looking into them to move to a flex tune in the future.
white1
Prairieville
LA
Ive installed a few in Scat packs and it is very straight forward. Ill post up after I do mine in the hellcat, but I cant imagine it is much more involved
Metairie
LA
19 Charger HC
Thanks, what shop are you with in Prairieville?
white1
Prairieville
LA
Demon Motorsports in Baton Rouge
parttimer
crazyweathertown
I have a hodge podge pump kit, sounds weird, but you can get most everything you need from Rick at Tapped to add to another fuel pump. Mine didn't have the pig tail for the fuel regulators so I got that from Rick, that allowed me to use a non Rick pump with no cutting except the fuel level sender.
