Brakes on 2018 Charger Hellcat
My 2018 Charger Hellcat is due for some brakes...still has original Brembos. Thinking of doing the PowerStops. Are PowerStops still the go to alternative to the Brembos?
Planning on going back to the PS4s as well.
Appreciate it all.
The rotors are toast too?
Not sure...they looked fine when tires where rotated...might just change them while I'm at it. Any suggestions? Car has 45,000 miles now.
SANTA CLARITA
2017 Charger SRT
I’ve read some good things about the EBC Yellowstuff brake pads…I may buy these the next time I need brakes. As for rotors, I’m leaning towards the Demon Performance or RB Performance lightweight rotors. However, there are less expensive OEM alternatives…DBA makes a replacement rotor ring.
I've switched to PowerStop Z26 on all my fleet - daily's and the Hemi's...good compromise of low dust and decent performance, also have been pleasantly pleased with their performance slotted rotors too. I believe I have seen catalog photo evidence of a part number for the Hellcat 2-piece front rotors, but have never confirmed if they are actually available.
I've switched to PowerStop Z26 on all my fleet - daily's and the Hemi's...good compromise of low dust and decent performance.
You mean....NO dust..I luv em
Ha, well. If the rotors are still good, you are going to be into this for less than $300 for PS pads! If I am reading my Amazon purchases right may be less than $200! If they still have slots, noting is more kind to those rotors than the PS pads.
Can our rotors be turned or is that not something they do anymore? Have a great day all.
PowerStop Z26 pads here as well (y)
Pictures of slots
At some point I will probably go with Powerstops, but only to minimize dust. Right now I am attempting to achieve goals with the car and stopping ability is more important than cosmetics. I will stick with OEM until I am done verifying the mfr's claims! Then I will retire and be satisfied enough for the PS pads. ;)
Pictures of slots
Great idea @DGatzby and @BULL. I appreciate any suggestions and opinions.
Fronts are here...
Thanks again. Front brakes are squeaking...which they have never done before. Thanks all.
Fronts are here...
About 1/2 - 2/3rds gone, turnable IF you can find a good lathe operator.
H-bobbins look ok from what I can see, but inspect the clips thoroughly if you use them again, they tend to start cracking after lots of miles and/or hard use.
Ok to use if you do get them turned AND are only driving in a "sane" fashion. Road course would want new with full mass.
Before worrying about or chasing any squeaking, do a fresh bedding and then evaluate, as always, be extra diligent about safety when bedding.
I'm still not able to supply any hardware, sorry, it's a painful story.
