Climate buttons under screen
Chicago
2018 jeep grand Cherokee trackhawk
Ever since today my ac has been off and the climate buttons under the main screen don’t work at all. When I try to turn the climate on using the screen it still won’t turn on. Think it’s a blow fuse and tried replacing corresponding fuses using research but even after replacement still the same issue. Don’t know what to do does anyone know or have any suggestions towards a solution?
06SRT10NR
Knobnation
try disconnecting the battery for an hour or so. if that doesn't force it to reset, try a factory reset [it's buried in the menues, location varies by year/model]
J
Chicago
Thank you I will give it a try. I appreciate it
