- Member ID
- #1319
- Messages
- 81
- Reactions
- 59
- Likes
- 17
- City
- ST PETERSBURG
- State
- FL
- Country
- United States
- Vehicle
- 05 Maggie GTO
- Remote reservoir front bumper replacement that also mounts our Interchiller, works with your IC reservoir and makes our Interchiller 100% bolt-on with or without HX bypass. San ice.
- Battery replacement reservoir/ice tank 100% bolton. (replaces front battery and relocate battery to trunk)
- Ice tank for trunk mount (for use with or without ice)
- Black insulation sheet to insulate against heat and condensation. Also helps reduce coolant temperature. 36"x48"x1/2" -300*f to 250*f R-Value 2.0+ (requires your spray adhesive)
- Black insulation sheet to insulate against heat and condensation. Also helps reduce IAT. 36"x48"x1/2" -300*f to 250*f R-Value 2.0+ ( With Pressure-Sensitive Adhesive )
- 3/4"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Pre-slit/pre-glued with over flap. -70*f to 220*f, R-Value 3+ 1.75od
- 3/4"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps IAT. Unslit, -70*f to 220*f, R-Value 3+ 1.75"od
- 1"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Pre-slit/pre-glued with over flap. -70*f to 220*f, R-Value 7+ 2"od
- 1"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Unslit, -70*f to 220*f, R-Value 7+ 2"od
- 2x AN-6 90-degree push lock style for rubber hose
- 2x AN-12 90-degree push lock style for rubber hose
- 2x AN-16 90-degree push lock style for rubber hose
