Stock Hellcat Exhaust Manifolds VS. Kooks Longtubes - Any Power Gains?
ostmike
Portersville
2015 Hellcat
Unscientific testing on the same car, same dyno, same tune.
If 150* to 170*ECTs are worth 40 wheel… how bad is it at 200*?
ostmike
ostmike
Portersville
2015 Hellcat
I have to be honest and say something doesn't seem right here. This is why we repeated the hit (did two total hits) at 150 degrees just to confirm. I think the test would have been more informational if I would have done a second hit at 170+ degrees and if the same WHP was obtained as the previous 170 degree hit I could stand by the results and answer your question with more confidence.
What I can answer with confidence is the power gain with the headers in before/after tests at 150 degrees.
To avoid confusion we probably should have left the 170 degree hit out of the video but left it in so everyone could see what we saw and come to their own conclusions.
I appreciate that you left it in!
I think it shows that you were willing to make 0 HP if you had to, but that you didn't overlook the variables at play between the before/after runs, and then you ran it again at 150*. It was the right thing to do.
Were cats used on both? I see them on the factory exhaust when dropped, but wasn't sure if they were retained with the headers.
