- Member ID
- #1319
- Messages
- 81
- Reactions
- 59
- Likes
- 17
- City
- ST PETERSBURG
- State
- FL
- Country
- United States
- Vehicle
- 05 Maggie GTO
Active Interchiller is the original Chiller that developed Competition Mode and Automatic HX Bypass in 2009. We have the only Progressive Refrigerant Distribution Device in every core and CNC Refrigerant Adapters for a no AC hose cut installation.
2011+ Grand Cherokee & Trackhawk
We supply modified New OEM Liquid Line, Competition Valve, wiring harness, relay, 10' insulated hose, switch and LED for the only true Plug N Play Hellcat Interchiller Kits. Our Programmable Automatic HX Bypass upgrade is compatible with any pump and allows you to retain your HX. We provide you a measured amount specification for refrigerant that is less than 2lb system total due to our 2 fitted refrigerant hose no-cut design.
Competition Refrigerant Adapters
No HX bypass $1299
Automatic Digital HX
Bypass Upgrade $150
Stage 2 Upgrade $549
No HX bypass $1299
Bypass Upgrade $150
- Show All
