- Member ID
- #975
- Messages
- 12,591
- Reactions
- 67,047
- Likes
- 402
- City
- Sketchy
- State
- MI
- Country
- United States
- Vehicle
- 2016 Challenger Hellcat M6
Yes, running hard for 30 minute sessions, OAT never higher than 75. I call up the performance pages APP on the UConnect screen and have oil pressure and oil temperature displayed on the track. At NCM on May 29/30th I was WOT for 5-6 seconds three times on the long straights every lap, with RPM's constantly up and down between 3,000 and 6,300. I thought I'd see hotter oil, especially the few times I pitted without a cool down lap, but 233 was it.
I found this marketing blurb about the upgrade SRT oil filter a while ago (there are two that are OEM filters). Your oil isn't dirty, but note that the Red Eye engine has two high flow oil pumps. In the "leaving no stone unturned department", I wonder if there is a way to know that both are working in your car? Just a thought...
"Mopar SRT engine oil filter is worth slight cost increase because the high flow oil pumps in our large engines can overpower the internal relief valve. When this valve opens it allows some of the high pressure dirty oil to bypass the filter element in order to keep the filter from being damaged. The SRT filters do indeed have a higher differential bypass valve to make sure all the oil delivered to your power plant is clean. The housing is slightly thicker than many of the brands out there to handle the pressure. The media used is one of the latest synthetics that allows very fine filtration, more debris capacity, and much lower restriction than our standard Mopar filter. The final result is cleaner oil, all the time, with more pressure to the internals where it is needed.”
