Suspension Control Module CONNECTOR - How to remove and replace?
#61
Have you tried disconnecting the battery, disconnect the BCM. Let the car set for 30 minutes. Connect the BCM and then the battery and test drive the car. I have the unit in my Hellcat and Redeye with no issues.
AlleyCat
Oro Valley
16 HC Challenger
#62
Tried disconnecting the battery. When you say to disconnect the BCM you mean the module wiring?
#63
Disconnect the connectors from the unit. Be sure you don’t have any pin damage on either plug. I remember one of the connectors has an awkward clicking alignment.
#64
What warnings were triggered?
