Information of Known Hellcat issues reported by Owners
Skrelnik
Fairfield
Here are the problems I have had with my 2017 ...
New - Dust spots under paint on matte black hood. Took about 6 months but they agreed to repaint under warranty.
1 year old - Car would not start. Diagnosed as a bad radio causing a dead short that drained the battery. Replaced Battery and Replaced Radio under warranty.
1 1/2 years old - Passenger side auto sense window (the window goes down a bit when you open the door) stopped working. Diagnosed as a bad switch. Currently there is a back log of 30 switches nationwide. Waiting for a delivery commitment. Guess I am not the only one with this problem.
What kind of dust spots appeared on the hood. Any pics?
KonaLaury
Kailua Kona
HI
2017 Dodge Challenger Hellcat
As you know the hood is painted in the original car color and then is painted matte black over the base color. In my case there were a few small pieces of dust on the hood when it was painted black and so you just see a small blemish (spec of dust) under the black paint. Sorry no pictures.
Ridiculously slow read time for TPMS on Charger HCs, and very long latency of TPMS error indicators (more an annoyance than anything else, but this is low hanging software fruit)
Skrelnik
Fairfield
This gets me thinking as I have this odd paint blemish on the top of the driver side rear quarter panel, definitely under the paint but also raised. Looks like a catepillar died on the car prior to the paint job. When I had the PPF done, the shop asked me if the car was ever in an accident and resprayed but sounds like poor quality assurance from the factory. Does your blemish look anything like this, zoom in to see it, this is the only picture I currently have:
My 19 Challenger is similar.
Takes up to 15 minutes for TPMS to show accurate info.
Also takes about 5 to 10 minutes to show accurate outside air temp
Skrelnik
Fairfield
Same here. Two weeks ago, while on the highway, I drove over a nail (not on purpose). I managed to get home with 8psi left. I then jacked up the car and let it sit while I took the wheel/tire to a patch shop. When I reinstalled the wheel it took like 15 minutes for the TPMS to update and recognize the new pressure. I even pulled my air compressor and tire guage/air filler to double check everything...just the TPMS taking its time to update.
When I got the new PS4s one of the tires showed low but went away within 5 minutes...nothing too long.
HarleyHetz
ARLINGTON
That's a LONG caterpillar!!!
Skrelnik
Fairfield
Yeah, right. Is that what the poor paint job looks like, that other forum members are speaking about? No pics of any other bad paint jobs on the forum, only people talking about it.
Matt someone with an SRT
Newtown
Don’t forget the annoying rattling sound. Haha. I got to fix this in my charger. Happens on cold days hitting jarring bumps on the road. Comes from behind rear seats. But sometimes you think it’s the passenger area.
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Rattling exhaust actuator valves.
Mine just started acting up, with 65k, on the clock.
Really bad, at cold start.
Always, at lower rpm (accelerating from a stop).
Any feedback, on this? I've read a few references, to this. No direct experiences, though.
Bob
Bob
I asked my tech about the actuators and he said MFERS as a solution...if out of warranty might just do that. Curious what others think...
Diboblo
Riverside
Well... I'm running Vibrants, so they prolly won't warranty it. LOL.
MFERS looks like the way to go.
BTW, I think it's the valves, themselves... not the actuators. When I replaced my actuator springs, i noticed black buildup at the valve head slot, where the spring mounts. Like it has been oscillating, and now is worse.
MFERS will keep constant tension, on the valve, which I hope will mitigate the rattle.
Bob
NYCSRTATE
NYC
Charger Hellcat
Bob
MFer1 will solve that, another reason I did that mod. I knew as the car got older they would rattle like crazy!
BTW I have Vibrants #1795 on my car also.
HarleyHetz
ARLINGTON
I bought the MFers but have not installed them yet, I've got about 200 more miles before the first oil change, they will be going on then!!
Auburn Hills
2020 Challenger SXT
Hi Matt, Feel free to let us know via private message if you plan to work with your dealer to resolve this. We are happy to provide you with additional assistance during that process.
Rob
DodgeCares
Newtown
Rob
DodgeCares
Cool, I appreciate that. Hadn’t gotten a chance to get around to it. I think it may just need a little insulation or something. I think that cover piece over the rear behind rear seats might be vibrating a bit over jarring/rickety bumps on some clips/plugs or screws on the underside. Only happens in the cold though. The roads can be pretty bad around PA sometimes.
Auburn Hills
2020 Challenger SXT
Thanks for providing more details Matt. I understand that the sound only occurs when the weather is colder and that it sounds like it is coming from the interior. I kindly recommend having the dealer inspect the sound to make sure it is coming from your interior and not underneath your Hellcat. I also recommend visiting the dealer on a colder day to make sure they are able to replicate your concern.
Rob
DodgeCares
Newtown
Rob
DodgeCares
D5889406-36B1-481A-8D8F-226D5D0648DE.jpeg 4C605F50-D757-4F79-BE40-209E5F625F55.jpeg C6C4FCC6-E860-4215-A4F0-341911EDCDD3.jpeg Found it! Had my dad lay in the trunk when I went over bumps.. it’s the metal retainer screws. They are under a little plastic piece. Also I taped the emergency latch and the latch under the trunk.
