Better late than never cradle lockout
Guess it's better late than never. I've been hesitant to mess up the on road manners, but several of you guys convinced me to take the plunge. Install was easy, but getting up and down off the concrete not so much :LOL:
Update - First drive.
Welcome to the ‘I just worked on my car and I can’t get up’ club. I’m just short of getting a Life Alert.
Dude, the next day I was like WTH is up with this. It also seemed like every time I got laid down on the floor I had somehow managed to grab the wrong socket and had to get back up and go to the workbench for the right one and do it all over again :rolleyes:
Put any street miles on since? Mine isn’t bad for ride quality
The luxury life is getting to you:LOL:
I find the more I crawl under the car the easier it is:unsure:
You actually may have a point there. I dont have to work on this thing too much (knock wood).
I noticed doing 1 bolt at a time it drops enough to get the ring in at the top. My lockouts didn't have the ring but there was enough of a gap I could have put them in. I also didn't unbolt the shocks. A tip if you ever have to unbolt the shocks again, unbolt from the lower control arm. The tabs were not bad to pry off it is all in the angle. I talked to Darrel after doing mine and he said he used a crescent wrench to pry them off. Per my write up I loosened the bolt but didn't take it out when prying
I got exhausted from watching the video.
Speedy's Garage, the only garage in Tennessee certified for food safety by the Board of Health.
I had to drill my limiter plates out as well, but wasn't too hard, as noted, with a new bit. All in all a pretty simple job, just a bit time consuming. I did it before I had the Quick Jack, so getting the car up and down took longer than necessary. Greased my rings to ease installation and minimize any noise as well. Nice kit for sure. Love to do the diff lock out next. We'll see. No increase in NVH for me.
My limiter plates didn't wanna just pry loose. I tried a couple different pry bars up to the biggest one I have. Maybe I wasn't getting it in the magic spot but I started to worry it was gonna tear up the bushing it was stretching the center so much. Drilling took 5 minutes and the bits are like $8 so not a big deal. Just go slow the gas tank is back there after all ;)
You can remove the lower shock bolt instead of the upper ones. The issue there is that to re-tighten it the car has to be at ride height and suspension loaded with the weight of the car to get it properly torqued. Those bolts are hard to get to with the tires on and the car on the ground so the top shock bolts are how most everyone does it.
Whatever you do, don't follow BMR's instructions. They have you take half the car apart.
zhc
2016 Dodge Charger Hellcat
This has been my life with my Hellcat for the last 6 years I've owned it...
zhc
Dunno if it means anything but, I don't have the diff lock out on my Hellcat, just the DIRS front and rear brace from Performance Development.
Every time I’m on the floor under the car it’s just so peaceful I start feeling like I want to take a nap. What’s this deal with cradle lockouts? 😝 B760FDE7-B8F4-4056-AE7A-C82A25B3453A.jpeg
Makes me feel a little better knowing I'm not alone 😂
by loosening the bolt and not removing it, the bushing doesn't flex as much
think once you get in your 40's it is harder @jonx96 was crying about it so for some it is even earlier:whistle:
Every time I’m on the floor under the car it’s just so peaceful I start feeling like I want to take a nap. What’s this deal with cradle lockouts? 😝 View attachment 77896
that looks like a dream so maybe you were asleep
I’m old ok 😂 heck my cradle lockout was easy. Darrel had it done by the time I was done talking to Craig
Ive got the DIRS as well, front race brace too. Just looking to keep the car together, got both parts used and on the cheap!
