- Member ID
- #972
- Messages
- 4,703
- Reactions
- 33,179
- Likes
- 252
- City
- Bucks County
- State
- PA
- Country
- United States
- Vehicle
- 2015 Charger Hellcat
2015 - 2017 Hellcat (compared to base 2015 Hellcat):
714 HP @ 6200rpm measured, 707 HP @ 6000rpm advertised
652 TQ @ 4800rpm measured, 650 TQ @ 4800rpm advertised
2018 Hellcat (+ electric power steering, widebody option with 20x11 rims)
730 HP @ 6200rpm measured, (+16 HP), 707 HP @ 6000rpm advertised
654 TQ @ 4800rpm measured, (+2 TQ), 650 TQ @ 4800rpm advertised
2019+ Hellcat (Combined air-flow rate of 1,048 CFM, after-run chiller, torque reserve, dual scoop hood, line lock):
745 HP @ 6200rpm measured (+31 HP), 717 HP @ 6000rpm advertised
662 TQ @ 4800rpm measured, (+10 TQ), 656 TQ @ 4800rpm advertised
2019+ Redeye (Combined air-flow rate of 1,130 CFM, 2.7L SC @ 14.5 psi peak boost, 6500 rpm rev limit increase, 25 engine component upgrade including strengthened connecting rods and pistons, high-speed valve train, fuel injection system and improved lubrication system, SRT Power Chiller, 700 cc fuel injectors, Two dual-stage fuel pumps, steel prop shafts (driveshaft) for 15% increase torque capacity (2lbs heavier), 41-spline half shafts for 20% increase torque)
793 HP @ 6200rpm measured (+79 HP), 797 HP @ 6300rpm advertised, 812 HP @ 6400rpm measured
709 TQ @ 4800rpm measured (+57 TQ), 707 TQ @ 4500rpm advertised, 719 TQ @ 4800rpm measured
2020 - 2023 Super Stock (Combined air-flow rate of 1,134 CFM)
793 HP @ 6200rpm measured (+79 HP), 807 HP @ 6400rpm advertised, 812 HP @ 6400rpm measured
2018 Demon (Combined air-flow rate of 1,150 CFM, transbrake, drag-mode suspension, Air-Grabber hood)
804 HP @ 6200rpm measured (+90 HP), 808 HP @ 6300rpm advertised, 812 HP @ 6400rpm measured
719 TQ @ 4800rpm measured (+67 TQ), 717 TQ @ 4500rpm advertised, 719 TQ @ 4800rpm measured
2018 Demon (+ 100 octane PCM tune)
835 HP @ 6200rpm measured (+121 HP), 840 HP @ 6300rpm advertised, 845 HP @ 6400rpm measured
776 TQ @ 4800rpm measured (+124 TQ), 770 TQ @ 4500rpm advertised, 774 TQ @ 4500rpm measured
2023 Demon 170
1,025 bhp (764 kW) @ 6,500 rpm with E-85 fuel
900 bhp (671 kW) @ 6,500 rpm with Premium 91 octane fuel
945 lb.-ft (1,281 Nm) @ 4,200 rpm with E-85 fuel
810 lb.-ft (1098 Nm) @ 4,200 with Premium 91 octane fuel
SAE Measured
812 HP @ 6400rpm SAE measured Demon/Redeye/Super Stock/Jailbreak
845 HP @ 6400rpm SAE measured Demon with 100 octane / Race PCM
Advertised Direct Connection Kits
Hellcat:
747 bhp Hellcat w/ PreStage Kit (2015-2018)
757 bhp Hellcat w/ PreStage Kit (2019+)
Redeye:
802 bhp (598 kW) Redeye w/ PreStage Kit
807 bhp (601 kW) SRT Super Stock & Jailbreak w/ PreStage Kit
840 bhp (626 kW) Redeye w/ Stage I (100 octane functionality)
837 bhp (624 kW) Redeye w/ Stage II (3.17 Hellephant pulley and 91 octane)
885 bhp (660 kW) Redeye w/ Stage II (3.17 Hellephant pulley and 100 octane)
Direct Connection Redeye Stage II
(+ 100 octane PCM tune; 180 tstat, 3.17 Hellephant pulley)
875 HP @ 6200rpm measured (+161HP), 885 HP @ 6400rpm measured
787 TQ @ 4800rpm measured (+135TQ), 786 TQ @ 4500rpm measured
Source: SAE Engine Power Certification Database (EPCD)
SAE J1349 certified results. Chrysler Test Center Test Cells C07 and C08.
SAE J1349 testing standards (SAE J1349 standard of 77°F (25°C) day with 0% humidity and a barometric pressure of 29.234 in-Hg (99 KPa)).
2023 Demon 170
SAE Measured
Hellcat:
Redeye:
- 8
- 3
- Show All
