Flex fuel build 93 & E85
Hellcat Dre
Active Duty U.S. Navy
Jacksonville
2016 dodge hellcat challenger
Hello everyone I am on the fence about what I should get to build for flex fuel. I have a 2016 challenger hellcat A8 I have already did a Bwoody race version heat exchanger
Jlt intake
Driveshaft brace
Dual oil catch can
Hhp 180 t stat
the reason I want flex fuel is a drive the car a lot in and out of town. I don’t want to worry about the fuel after it gets dialed in. I have not been to the track yet but is something I will evenly do as me and the cat gets better. How ever I do go to Mexico with friends more often than none. I do a lot of spirited driving if you my drift so I want something that can take a beating and keep going. I have been looking at the 2.72 griptec and the 10% lower and fic 1200 anything outside of that I’m open to
I would not do a 2.7x anything with a 10% lower if I spent the majority of my time on pump 93 octane.
You will want to pin the crank either way. Lower pulley or not.
greasy
HOFFMAN ESTATES
What are your HP goals?
Hellcat Dre
Hellcat Dre
Jacksonville
I would say 700-750 rwhp is my goal
Hellcat Dre
Hellcat Dre
Jacksonville
I would run E85 but want the Convenience of being able to put 93 also
greasy
HOFFMAN ESTATES
2.85 upper pulley w/ Demon Injectors on pump gas will easily get you there. No need for corn. I would recommend pinning the crank for insurance. T-Stat would be good too.
This.
If you insist on corn...you can get away with 1050x injectors and probably a BAP at that level but drop-ins aren't a big deal. The Rick Tapp Kit is real slick. 100% plug & play.
Corn on a 2.85 only should be 800whp.
Hellcat Dre
Hellcat Dre
Jacksonville
This.
I want to build for corn but run a flex tune
Hellcat Dre
Hellcat Dre
Jacksonville
I don’t want a bap I would rather do it right the first time with fuel pumps
greasy
HOFFMAN ESTATES
I am curious why you are so dead set on running corn?
What you are wanting to do is going to be overkill for the power levels you seek, not to mention you are going to spend more money than necessary to hit the 750 whp mark. A dual pump setup will cost you like $1,350, the injectors needed to run corn will be at least double in price, the flex tune will be more expensive than a standard pump fuel tune.
If all you want is 750hp all of the corn talk is unnecessary. Pump 93 and a 2.85 should get you there...saving you literal thousands over what you plan to do.
If you want to run a flex tune you will likely be at or just north of 800hp. Is this what you really want to do? A BAP at that level would be fine. That is all Barth uses on his similar powered packages. If you want the drop-in pumps you'll have enough E85 flow for well into the 900hp range. I run FIC1200's and if you don't at all plan to exceed 800hp you don't need the big injectors...1050 class injectors would be fine. Speedy has gone that route with much success but he is tapped out in colder (actually truly cold) air.
Hellcat Dre
Hellcat Dre
Jacksonville
I know eventually I will go further than just 750 whp why not build for it now I would rather do it. Right the first time and get parts that are good for both
Hellcat Dre
Hellcat Dre
Jacksonville
I do plan to go further down the road just not at the moment. I want to see how the car does at 750whp range learn the car. We always want more hp eventually I’m just trying to take it a step at a time
greasy
HOFFMAN ESTATES
If that is the case then just go directly there because you will spend the same amount of money. You'll make over 800 on this setup. Here is what you need:
2.85 Pulley
FIC 1000's or ID 1050's Injectors - Whatever your tuner prefers
Dual Pump Kit Complete
Crank Pinning Kit
Tuning Interface Diablo or HPT - Determined by tuner
Blower Spacers/Blanket
Here's my advice, pick the tuner you plan to work with and buy the package they recommend. You'll be miles ahead and will avoid buying parts you don't need, or the wrong ones and end up having to sell them on the forum for half what you paid for them. I'm a fan of Mike from OSTDyno.com and Curt from Dusterhoff tuning personally. Both are on the forum from time to time as well to answer questions.
You'll need to decide what pulley type you want to run, either a fixed pulley like Metco or a decoupling pulley like the Hellraiser which is setup the exact same as the stock pulley (same company makes them). Fixed are easier to change around for different power levels, but decoupler is supposed to be easier on the supercharger. Decoupler can't really be swapped around, at least not easily.
I can't tell from the pictures what rear tire you're running, but better add a set of Nitto 555R G2 to the shopping list or the car won't be drivable at anything more than 30% throttle.
Then you really should sit down and have a good hard think about what exactly you are aiming to do here power-wise.
The path changes substantially once you Crest that 850ish mark.
Ask me how I know.
GearHead is in florida. Jensen Beach I believe. Call them up and see what they recommend.
Otherwise Dusterhoff is in Georgia and works a good bit with Allpar Garage. Another good option depending on which end of florida.
Hellcat Dre
Hellcat Dre
Jacksonville
2.85 Pulley
Crank Pinning Kit
Thanks for the info I didn’t even think about blower spacers
Hellcat Dre
Hellcat Dre
Jacksonville
Thread Starter #18
Ask me how I know.
How do you know ?? Lol I have time
Hellcat Dre
Hellcat Dre
Jacksonville
Thread Starter #19
Yea I think I will hit up curt he has tuned two of my friends hellcat that are both over 900+ to the wheels
Grape Ape
Braselton
That's a great choice.
