Fore double pump install
parttimer
crazyweathertown
I bought a used double pump, got ZERO instructions with it, Fore says contact the vendor who sold it, well, they guy doesn't know who sold it since he bought it from a friend. So, here I sit with a pump and no idea how to wire it. I have pictures if that helps anyone!
P
parttimer
crazyweathertown
Thread Starter #2
Anyone? Or can I buy some adapters to make it plug and play?
Sent from my SM-G975U1 using Tapatalk
P
parttimer
crazyweathertown
thanks, i sent it to the shop guy to see if it helps him.
You could call any vendor that sells them for the instructions, or contact any shop that installs them and see if anyone wants to help.
A little help from either of those could lead to a customer, and the good companies know that.
Start by removing the carpeting from the trunk on the passenger side, that's where you'll make your connections.
Chances are, you have +/- to the battery, those pigtails hook into the stock FPM (or whatever they call it) and maybe there is some sort of boost reference or something.
I think @Speedy! made a video of the install, so youtube and google should help a bit too.
P
parttimer
crazyweathertown
yeah, speedy did a great install, but he had a fancy harness. I watched, he only had to create one connection. I have zero plugs, just wires.
Doublewide
Little Rock
AR
Looks like the livernois kit
P
parttimer
crazyweathertown
I started on it yesterday, got the tapped kit to help, next problem, guy didn't include the fuel sensor bracket.
