Incognito lower pulley
It will work fine as long as you run 93 doesn’t matter if it’s a redeye or hellcat ,da or altitude just install it and go have fun
Maxboost
Fuquay varina
Now that you mention octane I always ran vp octainum on top of my 93 when I went to he track. Around town it was just 93 and it never pulled any timing ever.
owensboro
KY
2019redeye hellcat
Are you guys using the Incognito for racing or just to have it for fun and if you don't use it for racing just for dd will it hurt the engine
MaxCarnage
Spokane Valley
19' Redeye
DD would be the easiest by far on it. Unless you got WOT you're not really using any performance parts properly imho. I'd run 93 octane just to be safe.
Yeah there sure does seem to be a lot of people running these and I haven't seen any problems yet, but it is a very new product, like less than a year old really. Tempting not to get one, it is on my mod list at this time. I can only make 11-12 pounds of boost here at just over a mile high, would love to get that back up to 14 psi. I can only get 91 octane pump gas here, don't know if 93 would be required then to run 14 psi? Isn't the recommended(or should I say minimum required) fuel at sea level for these cars 91 on the stock tune?
As far as needing a tune, there are a lot of people running these on the stock tune,and Steve at Ripatuned says you definitely do not need one to run it.
Maxboost
Fuquay varina
Yeah there sure does seem to be a lot of people running these and I haven't seen any problems yet, but it is a very new product, like less than a year old really. Tempting not to get one, it is on my mod list at this time. I can only make 11-12 pounds of boost here at just over a mile high, would love to get that back up to 14 psi. I can only get 91 octane pump gas here, don't know if 93 would be required then to run 14 psi? Isn't the recommended(or should I say minimum required) fuel at sea level for these cars 91 on the stock tune!
Normally with 91 octane you would need octane booster but at your elevation you may be ok. I would not run it without a datalog in any situation. Datalogs are easy and you can even use a lock tuner to do it.
Yeah I think you are right, there's nothing better for peace of mind than knowing for sure on that data log that it's running right. Thanks!
MaxCarnage
Spokane Valley
19' Redeye
Just FYI, FAS makes these for Ripatuned
Interesting and good to know. I've just seen the name "Ripatuned" on them. Didn't know he outsourced them.
Mopar gummy
ESTERO
18 Charger Hellcat
Make sure you tune, anytime you add air, better add fuel, don't care how they market it!
Mopar gummy
ESTERO
18 Charger Hellcat
It’s made by FAS?
It damages anything your on your own, they don’t stand behind anything
The incognito is ripatuned
swatdocsc
Law Enforcement
Jefferson City
MO
I ran it in mine got great results just keep the octane up on it, I decided to go the Hemituner H/O route and went with an ati instead. and my hey I'm just going to do a couple of things has grown into a project. message me I'll send a dyno video of the run.
Well I just ordered one with the crank pin kit
swatdocsc
Law Enforcement
Jefferson City
MO
It's definitely going to throw a few monkeys in the trunk for sure you will feel it. remember octane...
2 psi is like 40HP right? Not sure it'd be worth it for just that.
I’m trying to start small since I’m doing the install myself also not trying to spend a lot of money. It was 900 with the crank pin kit. I emailed josh at dusterhoff to see about a tune after so I’ll see what he says and go from there
For your case doesn't sound like the right solution. An email tune will get you more and leave the rest stock for now.
I dunno, I mean 40 hp for less than a grand is pretty good...what else pays off like that? I’m curious if you consider this to be a safe mod though?
Safe is stock and even that is questionable lol.
You'll get more from just a tune.
So we are going to tune it after I get it put on, prob be after Xmas though😫
