Safe for Supercharging the 392?
MJS73
Moparland
2020 Challenger Hellcat
Base: $58,995
Dest: $1495
T: $60,490
PD: -$7170
Net: $53,320
From what I understand, many guys received dealer discounts and paid way less.
Me included but Power Dollars (which had a different name in 2020) were not available until the very end of the year.
20HCM6 22RENBS2
July? And that's the only name I ever knew or heard.
I bought my 2019 HC in Feb of 2020 brand new and it had PD. If I remember correctly I think they ran them for at least 4 or 5 months straight.
Taxinator
SANTA CLARITA
2017 Charger SRT
Before I bought my 'Cat I did a fair amount of digging into adding a SC to a 392 car. I really wanted that shaker hood ;)
Pretty much every road lead to upgrading the internals if you really wanted to make it 'safe & reliable' and even then you needed to be conservative with the tune/boost. Procharger seemed to be the preferred build (actually the only choice if you wanted to keep the shaker hood).
So, can it be done - yes, but it will not be a cheap project and you will need to be conservative with the boost/tune.
Procharger and Vortech let’s you keep the shaker, but the Vortech is relatively new.
10.53 at 130mph
Not bad for a scat pack
You'd be miles ahead to trade for a Hellcat. This is coming from someone that built/supercharged a Challenger before Hellcat were available and traded that car in on a Hellcat.
Xylander
Tallahassee
I got Power Dollars on my 2020 HC in May of 2020. Mine had an MSRP of $77k, but I ordered it decked out to the max and financed something like 68k after vet/first responder discount.
Jon-MooredPerformanceLLC
Martin
2018 Dodge Challenger Hellcat
one thing I never like about tuning boosted scat packs is no wide band. I make the customer purchase one but it is just for logging purposes the pcm will not read it. I have heard a lot of tuners aren’t remote tuning boosted scars anymore. I still am but my final tune is usually fairly conservative and tuned a smidge on the rich side at wot.
Taxinator
SANTA CLARITA
2017 Charger SRT
The Vortech system comes with a Mopar 3 bar map sensor, so would the PCM read this one given the system was designed to include it?
That's to allow rescaling of the map/aircharge tables to account for the increased airflow so yes the PCM can use it.
Martin
It just has to be tuned for the sensor
RichNolen
RichNolen
Hobart
2021 Durango Hellcat
Thread Starter #32
Looks like I'm going with the 7 PSI ProCharger system with the P1X unit. Should be around 215 at the crank from what I have seen.
Just a sleeper 392 coming ....
MXS67454
Tampa
Dodge
Will you do the install and what are your plans for tuning ? the supplied tunes from any aftermarket SC company usually suck.
Just for fun 😝. Charger Scat with a 3.0 Whipple. Full weight daily driver on 91 and goes 9.3 at 150 on e85 at the track. Still running the 6 rib belt 😮 4880CF7B-D0CF-4757-892A-9B3793675AF4.jpeg
MXS67454
Tampa
Dodge
Just for fun 😝. Charger Scat with a 3.0 Whipple. Full weight daily driver on 91 and goes 9.3 at 150 on e85 at the track. Still running the 6 rib belt 😮 View attachment 108943
Still a 6 rib ? ..that's impressive..
Full length skinny belt on the 10 rib pulley. 579F1653-0AAC-4AA3-8EF6-1B2AD7B682E9.jpeg
RichNolen
RichNolen
Hobart
Thread Starter #37
ProCharger in Kansas City is doing it. They are taking care of everything, including the Tune.
MXS67454
Tampa
Dodge
Let us know what you think when it's done..
RichNolen
RichNolen
Hobart
Thread Starter #39
Will do. I will post the before / after Dyno results from them as well.
MXS67454
Tampa
Dodge
Full length skinny belt on the 10 rib pulley. View attachment 108966
I dunno, seems more likely the 10 rib belt broke and the 6 rib was used to drive it home. can't see a 6 rib holding well enough for the boost needed to trap 150
