Stock height measurements
Cra97
Katy
2018 WB Hellcat
Trying to dial in the camber and lowering with this new set up of wheels. I have adjustability of upper arms (AAD) and KW adjustable springs. I lost my sheet where I recorded the stock height ( ground to bottom of flares at all 4 corners) of my WB Challenger Hellcat. Does anyone have the measurements with stock springs/height? Just took a measurement and I’m currently sitting at 28 inches up front and 28 3/8 at the rear. I did a search and couldn’t find anything. Any help would be greatly appreciated.
Should be someone here with a stock height WB HC Challenger.
I have a stock suspension 2019 WB HC and just measured from the ground to bottom of flair in the middle and here’s what I got: front 28 7/8 rear 29 3/4. Hope this helps.
C
Cra97
Katy
2018 WB Hellcat
Thank you so much.
Glad to help. Good luck with your project. 👍
