- Member ID
- #1044
- Messages
- 4,933
- Reactions
- 26,827
- Likes
- 252
- City
- Riverside
- State
- CA
- Country
- United States
- Vehicle
- 2015 Dodge Charger Hellcat!
So, I had what I thought was the dreaded front rotor click... but this was more substantial. I pulled the wheel and found that the H-Bobbin spring clip had broken and was interfering with the outside rotor.
All in all, I had 5 spring failures.
I sourced some clips and set to replacing all 20 of them.
Here is my How-To thread:
https://www.hellcatforum.org/threads/how-to-rebuild-front-two-piece-rotors.8968/
If you are experiencing a substantial click, under heavy braking, take a look at the spring clips. You don't need to pull the wheel, to see the failure.
I only heard it, under heavy braking. In time, I'm sure it would have been a more dra.atic failure.
NOTE: These are Centric 126.63088 rotors, but of the same exact design, as the Brembos. Just trying to help identify a weak point, on any of these 2 piece rotors.
Hope this helps.
Bob
Hope this helps.
Bob
- 5
- 3
- 1
- Show All
