a
I posted earlier that I experienced the shift hesitation and took the car to an SRT tech. Well, the hesitation has returned (never left but was unnoticed?) I want to try to consolidate some ideas that I hopefully have correctly gleaned from posts on this subject about what might be happening. Like others, I have experienced the hesitation between 1-2 and 2-3 shifts. Usually one or the other but so far not both. I am wondering if the hesitation is caused by tire slippage. Once the tires start to spin, the max friction force is exceeded and additional torque produces an increase in tire spin which could cause an over-rev situation and a triggering of the rev limiter causing the hesitation. Because traction is dependent on the coefficient of friction (stickiness of tires, contact patch and road conditions), the weight of the car on the rear tires (static and dynamic) and engine torque, a sufficiently severe over-rev situation may not always occur. This might be why the Demon with it’s stickier tires and weight transferring suspension does not experience this hesitation. The hesitation of the Redeye without these extra goodies is just showing its weaknesses by hesitating during shifts. Anyway, my question for the group is this, Has anyone found that better tires and suspension upgrades have had any affect on the hesitation? I know that some have experienced the hesitation on the track (great videos by the way) with better tires, but the Demon has stickier tires with smaller diameter wheels and increased sidewalls with the suspension upgrades so maybe all are necessary to prevent over-rev? Driving a car with a mere 800hp has certain “peculiarities”. Whoda thunk? Anyway that’s my 2 cents!
On the street your theory is plausable.
But specicially on a good tire , the 315/50R17 ET STREET R's on the street it does not fix this. Not even close. Also the Demon DOES hiccup. There have been many threads on this. But in most cases it is minor and it will go away as the car learns or when you get on a better surface, or get better tires etc.
My car on the street with the ET Street R's would hold gears when in TRACK mode. So in drive from a dead stop you can roll the throttle down in first gear and get to WOT about 1/2 way throught first gear and the car will be moving forward real well and tracking and doing a rolling burnout and at that point it is hazing the tires and leaving grey marks (because it is not over driving the tires) and then when it shifts to second there is a huge hiccup and about a 8 foot gap in the marks and then they come back darker than ever. Two black lines all the way through second gear.......
It's that 8 foot gap that is a bitch. It's my contention that if the car shifted (in time or sooner) and did not hit the rev limit there would be minimal gap or no gap in the marks.
With my car the engine would crash hard into the rev limit. It was not suttle. In fact I actually think the car may have NEVER shifted under WOT. It could be the only way it was going to complete the shift was when the rev limit closed the throttle and reduced power. Once again, this is a maybe because there is no way to know for sure under the circumstances. Out of 31 passes it only completed the 1-2 shift on time ONCE and ESP (possibly Launch Assist) was reducing torque by about 100 foot pounds.
OK let me expand. If you eliminated the rev limit all together I suppose the motor would nose over at some point and then the trans would be able to complete the shift. So, yes it eventually would shift.
