First, thank you for all of your contributions to the forum.
Wish you all the best of luck with that new hot rod Super Stock Challenger.
What kind of 1/4 mile times are you hoping for when you drag race the new vehicle?
That is a good question. I think Dodge did what they did with the Demon, but I am sure they are aware of all the trouble it causes with the owners. So with the Super Stock they published the more traditional "everybody can do it" time of 10.50 @ 131. I expect that time is on Stock Tires with decent driver skills and track prep at +1000 ft DA. This is the stated .3 seconds faster than the RedEye Wide Body on the 305 Perellis of 10.80.
I have said I think that 10.50 time is way under rated. Mainly because better tires will get you quite a bit and then there is the typical weight reduction that you can do and there is negative DA. My last car put up exceptional MPH numbers and that was with the Hiccup. If I get another good motor like that one and with the drag focused calibration I expect this car might be hurting some Demon owners feelings. Keep in mind this car will not be lighter than a one seat Demon even after all the weight reduction I have planned.
I do plan on keeping the motor and calibrations 100% stock and I am hoping to get into the 9's when I get into negative DA down in TX etc. I sincerely hope my order is solid and the car gets here in time for me to prep it for my trip in January.
FCA knows I have my order in and they know I will be going right to the track and racing it. I did my part and made them aware. So lets see what happens.
