4.5L Whipple 'Murder Cat'
It sounded like one that's all. Ripatuned/Curt @ Dusterhoff tuning just put together a new shop car with their heads/cam/drop-in rods piston package. Spinning to 7400 rpm with plans for 7800-8k. https://www.facebook.com/watch/?v=952556701920012&extid=EucMIjhLfbTK2JVV
Whatever makes the car reliable longterm will be what i choose when building the motor/heads. High revving engines are always sweet but the cost of reliability isn't worth it for the end goal. If you're racing for money every season that's another story.
Could just have BES build you the one they built Turk :cool:
cole3986
TBD
#82
Jack,
Wow, that was a haymaker, I was thinking it, how do you really feel about it? FYI, the Hellephant is assembled by BES, I had one and sold it since I am going to be turning 7,900 RPM in the quarter
FFBOS
Mount Prospect
2016 Hellcat Charger
#83
We are still early on this platform. At what point are you considering rebuilding a motor that spins to 7k? I know they just threw those drop in’s in the stock motor, I would think it would last a long time.
MurderCat
MurderCat
Rochester
Thread Starter #84
Motor will be torn down/built when the dash reads 50k miles or serious internal problems arise. If sticking to the 5" plan hope to keep those stock rods/pistons happy.
Come build time going to make sure everything's blue printed, don't really trust 'drop-ins' long term - main goal is reliability. Definitely don't want a full on race motor like Turks 'Black Bird' that needs refreshing every season or after every race o_O Looking for a setup to last 5-15 years before a re-fresh is needed.
WhipCat
In the Jungle
I’ll use actual data.
I have yet to see a ihi car run a 60-130 on a street pull like this.
This is what wins street races. This is pure acceleration. This is why the whipple is is an awesome street blower.
WhipCat
In the Jungle
I don’t see a car running heavy boost lasting very long if your driving seriously on it. Especially stock motor. I would give a stock motor 1-2 years max.
I would expect a refresh needed every 2-5 years based on a built motor based on how much driving and how much racing. That’s just fair. Especially if it’s boosted heavily all the time
That's one of the down sides to E85..... You can run big power all the time which wears out parts quicker .
FFBOS
Mount Prospect
#88
Not a “problem” lol. It’s a drug.
I'm going to be honest here thats one of the things keep my engine alive...... The ultra soft pump gas tune I'm running.
Are you guys on E85 eligible to go to AA meetings?
FFBOS
Mount Prospect
#90
E85 is great fuel. Just have to know the limits.
MurderCat
MurderCat
Rochester
Thread Starter #91
We have some work to do now. Ripatuned RT900+ package (upper lower, bolt ons, OEM redeye S/C) just did 4.83 60-130. :eek:
WhipCat
In the Jungle
At the drag strip. That’s pretty common for mid to high nine second pass.
Do it on the street on radials
What radials?
I can blow the pirelli's off at 70 mph.
And what is this you guys are getting the screen shot from ...... I want to play.
WhipCat
In the Jungle
What radials?
It’s a dragy. Get one. It gives you very good metrics on your car. Allows to you see your acceleration and 1/8,1/4,1/2 mile times.
Tires are Mickey Thompson ET/R 305 20”
I’ve Never run a street tire on the rear of my car ever
Excellent...... I will look into one of those .
WhipCat
In the Jungle
Correction Indy they are the S/S
The R’s i run on my 17 racestars, they can also street drive but are to scary in the rain. I run the street s/s which is nice and sticky but better in wet and rainy roads. Those are on my 20” vossen wheels. Great street strip tire.
I’ve run 9.90-10.1 in the 1/4 on these right from the street to the drag strip. Excellent tire, but they wear fast. Usually change them every 3-4 months.
https://mickeythompsontires.com/drag-tires/et-street-s-s
I'm always shopping for a good set of tires . I get caught in the rain from time to time and I road this car as much as I can . So the street R's are out of the question. I don't care about the wear so much . They are consumable in my opinion.
Thanks Phil
James
MurderCat
MurderCat
Rochester
Thread Starter #98
Stand corrected, took another look you are right that was from a 9.42@149mph pass at the strip with a 15" drag pack.
WhipCat
In the Jungle
All good. 4’s is nuts on the street. If it was true that would be very insanely impressive.
zhc
2016 Dodge Charger Hellcat
Great response, however, IATs are much lower using an ice tank IMO. At Dan's event in Kentucky my IATs were below 90 F and it is was super hot day (well over 90 degrees). Maybe I am just ill informed, anyone with the chiller system seeing IATs in the 80s or below on a real hot day?
I went back and modified my previous post, it was too extreme
I use a Killer Chiller with a small 1.25 gallon tank, no ice and this is what I see normally.
Mine start low, in the 80's give or take and end up somewhere between 115 - 130F by end of the pass. I have custom Nitrous spray bars located below my IAT sensors so my temp readings are unaffected by Nitrous usage. I'm sure they're super cold though going into the intake ports with spray, it just doesn't read that way in my logs.
2019 lines were when I my IHI with a 2.50 upper + lower.
2020 lines were with my Whipple
Starting temp variance is more related to heat soak than anything else since it requires running the engine to chill the fluids. If I start the car thinking I have 5 minutes before making a pass, and there's a delay, then I generally see higher temps as a result because of the ensuing heat soak that occurs.
Surprisingly, I see similar temps now with my Whipple versus before with my IHI using the same cooling setup.
Chiller's are a viable option, when they work right. I've been fortunate enough to get mine to work well 98% of the time. There are others out there who haven't been as lucky.
