Thread Starter
#121
- Member ID
- #3104
- Messages
- 325
- Reactions
- 697
- Likes
- 67
- City
- Rochester
- State
- NY
- Country
- United States
- Vehicle
- Whipple Hellcat (Sold) 22 GMC 2500HD Denali
Thread Starter
#121
Update: Ordered the wrong stuff last week from Whipple. I simply don't understand why things are going so poorly.
Original email for work requested 9/4/2020 that was never replied to:
Here are things noticed installed wrong so far:
Here is a picture sent end of last week saying the car is complete: (Nothing was touched but the fuel line, told me it had all new whipple lines that were ordered when it still had the temporary hoses I installed in the meantime. Exactly how it left my hands
- No insulation on any coolant/A/C lines )
How i requested install and even sent this photo to help as a reference, it's little things but the only stuff i sent the car down for apart from tuning/chiller install, not sure how it could be missed:
- -Wrong vacuum fitting - needs whipple specialty 8AN o-ring to 15.82mm quick connect.(Photo attached)
- -Missing the correct Whipple vacuum hoses/QD fittings.
- -Evap hose setup is a bit odd
- -Fuel line routing is odd- 3 points of contact. Covered with DEI 3000 Fire wrap for safety in the meantime. - Would like to retain the wrap when adjusted. Needs heat shrink on the ends for clean install.
- Stalling when 'cold' started in 70 degree temps. Rough idle.
- Breaking up before WOT. Seems to hit a wall then GO.
- At stop lights, foot buried will lurch forward/shake odd every few seconds. Doesn't seem to do it when held on a hill, and didn't do it before mods 7/27/2020 -> Will be doing Dodge's V86 recall for most current TCM/PCM flash to eliminate variables before sending the car down. Curt/Josh believe this will 99% be the fix. Otherwise may need to upgrade the converter.
- HP Tuner PCM may have Wideband mapping cal off if not a mechanical issue. -> Sent them an email.
- Get the car 100%, clean up any sub-par installation - clean install - track safe.
- Finish Tuning with Dusterhoff LLC on 5" 93/E85 Flex and 4.5" E85 Race -> Confirm driveability.
