Sign Up! To view all forums and unlock additional cool features
Does anyone have the ride height numbers in inches on the different spring setups, ei Hellcat/ Scat Demon, and so on I just put the complete set of Mopar Demon springs and it seems it sits a little higher. Thanks in advance.
Had dealer install the blue mopar springs before I picked up car.
Really hoped it would drop more than it did.
Have a box of eibachs, need to be installed though.
They drop at least 1 inch front/rear (with what I recollect).
FYI:
My "Recollector" is a bit used/dated/aged/worn out.
So I may be a "tad" off.
Yea, on my 16 I had Eibachs. Had a boot tear on left side.
Don't know if it was due the eibachs, or if it happened before.
Guessing it was due to lowering springs, as others have mentioned it as a cause.
This thing rides like Grandpas Oldsmobile now with the demon springs and sway bars, reminds me of my 72 a little but definitely bites better. But your Silver cat's stance is hard to beat Bull. and yes I'm trying to improve my launch and overall traction which was nonexistent before. In Oct I'm trying my hand in the standing mile.
@BULL and @Hunter sorry for the necro-thread revive, just passing the time while I wait for my (standard) HC Challenger that I ordered, but the picture that BULL posted is the EXACT look I'm going for and wanted to know if either of y'all had the part numbers for those MOPAR lowering springs...?
When the time comes that the stock tires are (literally!) smoked, I'd like to go with a wider tire (285/40/20 I think...) and maybe spacer(s) to fill out the wheel wells a little better, eventually going with a staggered setup with 10.5 rears (and 305s), I just REALLY like the Brass Monkey wheels I ordered and hopefully can get some rear repros to get the extra width.
I also have the Mopar springs installed.
Had dealership install before I took delivery.
If you want even lower, eibach makes springs for the Challenger.
But, if you are using wider than stock wheels/tires, expect some light rubbing on wavey roads.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
