Like I said, they generally fit eh..
ok. But when I got the flare on the end of the pipes to sit perfectly square and even on the beveled end of the factory exhaust header ( where they were perfectly even all around the flange), they were hitting the floor on the pass side or the tranny cross member on the drivers side. I kept playing till I found the happy medium, but still too close for me (@ 1/8" to the floor on the pass side and 1/16" or less to the tranny cross member on the drivers side). The wrap wouldn't even fit between the crossmember and the pipe, I had to use the pry bar again just to open up the clearance temporarily and then pull it through. But the big picture plus is....NO LEAKS!
