Electronic rust proofing fixes the rusty rotors. Depends on how ocd you are I guess
I took the wheels off. Demounted the calipers, and then Scothbrited the rotors.
Then I polished them on the buffing wheel, and then finally coated them with platinum.
:whistle:
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Using them takes the rust right off.
Go figure...
:whistle:
Bull I am thinking it is time for an intervention 😂
Over at CDT, I spent $6000 on a nickel coating that only lasted for one dyno run before I melted it (it was an alloy, not pure, so it had a comparatively low melting temp)
So
so does chocolate..(and taste much better than crayons)
AeroF16
Phoenix
Whoa, whoa, whoa. I don’t know if you know who you’re talking to here!
In another life..he sent me up...tell em bull
It was that guy out of California, I don't even remember his screen name anymore.
Lazer Doc:unsure:
AeroF16
Phoenix
I was just referring to his enduring love for eating crayons as a prior Marine.
I was just referring to his enduring love for eating crayons as a Marine.
Fixed it
Which no doubt contributed to his premature tooth decay issue...:D
Demoniccat
The D-mon D-man AKA 1971demon is used to sitting in the cooler for backtalk to the moderator. So a non issue LOL, heck the poor SOB would get locked up on other site just for logging in. He does add spice to the postings “fur sur”
Well...I've been called an SOB..forever...but poor??..I'm only 5'9"..till I stand on my wallet;)
Drove it over to the tire shop and had the drag radials rebalanced.
Still looking to wire a kill switch on an M6 car. Switch mounted and hidden. Starter relay option ng as it can still be push started. Looking at the blue/orange fuel relay wiring that runs from trunk to fuel pump and looking to splice my switch into that beneath the rear seat delete. Now I see two blue/orange wires going into the d/s fuel pump. Any idea if it matters which one I interrupt with the switch? Thanks
Bath day!
Your drag tires, do you have beadlocks? I have found mine move so I don't balance them
