How to install the HP Tuners Smart Access Cable 2019 Redeye Challenger
Thread Starter #21
VICTORVILLE
Just to be sure, what gauge wire did you use?
I extended the Power and Ground wires as needed in the trunk near the battery. I used whatever wire I had laying around but likely it is larger than the included wire with the unit. Maybe 18 ga. I think the wires only had to be lengthened about 12-14 inches. There are 2 ground studs near the battery. I double nutted the forward one for the ground. Also if you have a really old unit I would measure the overall width of the piggyback fuse spades and compare to the OEM fuse removed. Some were a lot wider and pushed the clips out of the fuse panel causing an issue and PITA repairs. I filed mine down to within .020" .
white1
Prairieville
LA
2020 hellcat charger widebody
I've done it pulling the center console. The last couple I pulled the trim bezel around the radio and gauges and it was a bit easier.
As far as having the Zauto cable in the trunk, try logging from the OBD port in car ;)
I've never had an issue logging from the data port. I do not care for the bypass cable in the trunk as I like to log, revise and upload without having to get out of the vehicle, but that's personal. If I install the cable, I use the one from HPT, but I'm not going to add that one to a car with one in the trunk, I just deal with the inconvenience. I have, however, never had an issue using VCM scanner from the OBD port
Idoru99
Springfield
VA
2021 Challenger Redeye WB
I bought a long USB cable, about 10 feet and ran it from the ZAutomotive double bypass along the inside of the passenger door and up onto the passenger seat. There it just plugs into the laptop. I think I got a 10 ft USB cable, a little longer would give a bit of flexibility.
Honestly, scared the crap out of me to pull the dash apart, so the HP Tuners bypass cable is still sitting in it's box. Some day I'm sure I'll install it.
Thread Starter #25
Where did you plug it in at the ZAutomotive double bypass?
Thread Starter #27
My HP MPVI2 plus has a usb”c” you plug into then the computer.
Thread Starter #29
Hell yeah!!! So does mine. I’m deep in the learning curve here fellas. I appreciate the support.
No problem we’re all learning! Some just don’t want to admit it. HP tuners has a 6’ cable available that’s the one I’m getting.
Thread Starter #31
Idoru99
Springfield
VA
Thr MVPI2 is plugged into the double bypass in the trunk. The USB cable is plugged in there and routed up to the passenger seat. I just leave the MVPI2 plugged in all the time right now, since I'm still learning about logging and reading the log. I just log about everytime I'm in the car.
Snowman
Cranberry Twp
Subscribed
white1
Prairieville
LA
Just a heads up using a longer cable for the MPVI
my newest laptop uses a usb-c plug instead of a standard usb plug. I bought a longer cable and it wouldn't transfer data fast enough. I kept having issues. So if you need a longer cable, make sure you get one that is for data transfer. I guess a lot of the cheaper ones are just for charging phones
Idoru99
Springfield
VA
@white1 what kind of issues / symptoms did you see?
white1
Prairieville
LA
It would just stop while logging, while reading instead of the usual 9 min it would show 240+ min to read. Sometimes the time will bounce around anyway, but it actually seemed like it was going to take 6+ hours to read. Sometimes wouldn't write, sometimes would abort itself during a write
Idoru99
Springfield
VA
That sounds frustrating. I'll keep an eye out for that. Thanks!!
Thread Starter #39
Since I'm buying the HP cable I would assume it's qualified for data transfer.
Yes sir that’s the one I ordered.
@jgilj Let me know how this works out. I’m considering going this route.
Thanks
