- Member ID
- #1044
- Messages
- 6,241
- Reactions
- 30,475
- Likes
- 352
- City
- Riverside
- State
- CA
- Country
- United States
- Vehicle
- 2015 Dodge Charger Hellcat!
Any opinions on this? Apparently Plug and Play Kill Switch(es). $99 doesn't seem bad...though I'm sure you could piece it together yourself for cheaper. At $99, probably not worth my time to try do so anyway. My worries about a kill switch is hacking into a harness or running a shit load of wire through the car, or a fuse / bad connection going and bricking the car. I have another deterrent for my manual which inhibits being started...though this might be a 2nd deterrent if you make it through the 1st in short order. I tend to be more function over form, so I look at a kill switch (in some cases) more likely to fail on me versus my car getting targeted and successfully stolen.
https://carcatcreations.com/
If they've cloned your FOBIK, they don't need the button. They just transmit a start command, from their clone device.
IMNSHO, there are better ways. RF Hub lockout. FP lockout.
Hit up @Green717. We worked out a circuit and he installed that unique security solution. All DIY and not $100.
- 1
- Show All
