KW adjustable ride height spring set, BMR spherical bearing sway bar end links, AAD adjustable front upper A-arms with the spherical bearing upgrade, AAD adjustable inner/outer rear arms, AAD billet trailing arms with the spherical bearing upgrade, solid cradle bushings, front shock tower brace, rear shock tower brace, Per4mance DIRS diff brace, HR-5 9.5" front/11.0" rear wheels, Nitto NT-05 315/35X20 rear tires & Nitto NT-01 285/35X20 front tires.
While most consider the diff brace to be about preventing diff damage, it also goes a long way toward eliminating wheel hop. The diff brace and solid cradle bushings really made a difference.
