Taking the oil pan, windage trey and oil pickup off with engine in the car is not a fun time and it’s even worse going back in. Had to undo engine mounts and jack up engine to clear k member and get trey pan and bolt pickup back on before Mopar rtv sets up on 4 corners which is way too fast. Thankfully leak is fixed, I think it was because of pressuring crankcase (I now have a breather) and I snapped a bolt in the back for the rear main seal when I changed that when had the trans out (bolt has since been extracted and all new arp bolts and washers used for oil pan)
