HP Tuners Stand Alone.....CORE ECU
Anyone know if this will be available in the gen 3 Hemi platform? Satera just posted that they are doing one in a Magnum TT build. IDK if Jeremy is hacking into it to make it work with the hemi but he says its for LS setup but that hes about to change that...... Has digital dash option to.
From Satera:
"If you haven't, HPTuners has launched their very own Standalone, the Core ECU!!!!!
Currently, Its Plug and Play only for the Gen 3 and 4 LS setups, but we are about to change that😈
We are stoked to get this into our Twin Turbo Magnum, she will be a certified RIPPER!
Using the HPTuners CORE ECU, this means we can implement Flex Fuel, Rolling Antilag, Boost by Gear, and many more fun features, including a sick digital dash! So glad to get the nasty 20-year-old dated junk out, and the new hotness from HPTuners in!"
Supports up to 16 injectors and 8 coil packs
🟢Sequential fuel injection support
🟢Optional flex fuel integration
🟢Dual throttle body capability
🟢Built-in dual wideband controller for accurate air-fuel ratio monitoring
🟢Real-time tuning support with new VCM Live Software
🟢Data logging up to 150 channels at 1 kHz
🟢Advanced boost, nitrous, and launch control
🟢CAN bus support for seamless communication with external devices
🟢Motorsports-grade performance
https://www.hptuners.com/product/core-ecu-bundle/
It's very similar to the RACE gateway. Just allows you to use an aftermarket ECU. In this instance though I believe an HP Tuners harness is required. This means you would have to buy one similar to as if you were using a gen3 hemi with a Dominator stand alone.
It’s similar to a Holley without the race gateway.
I dont see a Hemi option am I missing something?
Nope, not released for gen 3 hemi yet.
then what the hell is Satera referring to? any idea?
