question about the height of et street bracket pro radials?
Ridgeland
SC
2016 hellcat A8 and 2016 M6
the 315/60/15" are 30.30 in height is anyone running the 315 on a stock height challenger? Or should I go with the 275/60/15" which is 28.20. What would you guy's think. I have set of 29.5/50/17" they I just bought never been mounted but I'm going to bite the bullet and go ahead and do the 15" conversion. Thanks
The 15” wheel with the 315 Radial Pro is the choice for the High Hp Hellcats. I started running that tire back in the day when I had still had the IRS suspension. Stock ride hight. No issues. IMG_9208.jpeg
rookerrobert
Ridgeland
SC
I got to ask what size and make of wheels are you running front and back.....your car very nice!!!! love it
Billet Specialties Winlites. 18” frontrunners with 15x10 single beadlock rears. IMG_1405.jpeg IMG_9206.jpeg
rookerrobert
Ridgeland
SC
Thanks Marc there sure are nice I'm looking on the website already...lol
Trackhawk, RS3, Golf R
If ur going with a 15 inch conversion I would opt for the ET Drag Pro Radial if ur looking for a track tire. Its ony avilable in a 15 unlike the PBR. If ur gonna street it id stick with the 15 inch PBR.
Do the 15s really hook “every time”?
rookerrobert
Ridgeland
SC
I'm going with the 315/60/15 315/60R15 Mickey Thompson ET Street Radial Pro. The only thing I don't like is I don't want to change the front but with the rear conversion has wilwood brakes my front will be brembo's. If I was to do the conversion on front I could match but at the strip it may be ok but I do drive my car on the street also and I just feel more comfortable with good brake on the front.At the dragstrip I run at in the 1/4 I really have to stand on the brake at the end of a run.And I'm only running 140mph
Parachute
rookerrobert
Ridgeland
SC
I dont think you have to have one till you hit 150 or thats what I was told.oh ok I see now what your saying but I truly dont want have to do that
Then keep your fronts and use a 4 piston rear. If you go to tbm all around you will want a chute
rookerrobert
Ridgeland
SC
I'm going to with 15" conversion on rear where I can run the 315/60/15" et street radial pro tires. but doing that it comes with wilwood brakes but I'm keeping the front stock I still street drive my car.
rookerrobert
Ridgeland
SC
But damn the front conversion is higher that the rear and less stopping power
Should be fine. Single piston calibers i’d never run without a chute (tbm) regardless of trap speed
