- Member ID
- #1058
- Messages
- 1,427
- Reactions
- 2,343
- Likes
- 212
- City
- Newtown
- State
- PA
- Country
- United States
- Vehicle
- 2023 Charger SRT HellcatJailbreak , 2019 RedEye WB
Hey guys.. just ordered an LMI intake for the Redeye.. have a Bwoody on my Charger already as some of you know.. Overall I’m happy with the Stock Filter on the Redeye.. really I just desire more Whine!!.. now on the Redeye we don’t have the heat extractors.. so when your sitting in the drivers seat you really don’t hear as much whine with the stock setup as I really crave for.. anyways I’m still super pleased how the Bwoody sounds... but I’ve always had interest in the Legmaker setup with the carbon tube.. thought it would give the engine bay a little cleaner look.. not really a fan of the rubber gromet and the closed box to hood even though it may very well be more effective at cooling in certain scenarios. So I wanted to post to see how many of you guys are actually going to aftermarket filters on your Redeyes or Demons.. it’ll be intriguing to see the actual IAT results. On my Charger I’ve noticed atleast a 10 degree drop in temps over the closed box. I’ll be interested to see now when the lmi is installed how it will perform. I’ve noticed the lmi sits really close to the hellcat Eye which will blow the air right in.. my other theory is since the intake won’t be connected to the right hood scoop you’ll get a lot of cool air into the engine bay as well as some getting sucked into the filter. I honestly think with the airflow improvement of the lmi design and the placement without a heat shield may result in lower temp especially on repeated pulls and days that are cooler than 80 or so outside.. it’s all speculation but I’ll post up results of IAT difference whether I see it positive or negative and I’ll do some pulls 0-100mph to see if I can beat my consistent 6.8 / 7.0 second range pulls. Really I’m just looking for added whine which I’ve watched plenty of videos where it sounds atleast twice as loud.. but I’ll definitely report on those other things I mentioned since I haven’t really seen much info/data On direct comparisons on the Redeye/Demon models intake AFM replacement.
- 1
- 1
- Show All
