Bull's Shyt #2
Ok, here's my 2nd round of thoughts on a very simple, mild/moderate, build (after cancelling the last effort due to issues with selected tuner and "life")
While the combination is likely capable of pushing the limits of the 1000cc injectors, for now, I think I want to stick with a mild tune and therefor the smaller flow units. Also keep in mind that I'm at altitude.
Tuner/Speed Shop:
  • FIC 1000 or 1200 injectors
  • Dual pumps
  • Crank pin
  • HP Tuner/credits (Have)
  • Flex tune
  • PCM unlock
Jokerz:
  • Jokerz ported S/C (already have)
  • Quick Change pulley shaft
  • Recoated rotors (maybe from another vendor)
  • New bushings
  • Powder coat lid black
CDT Rotors:
  • HCF 390-34-10H-O.E.-A 103 (1008-0576) Rev C (x2)
Fantom Motion:
  • 2.72 Pulley (Have already)
  • Polish snout, bearing plate, body
  • Fuel rail upgrade (per @16GoManGoHC2 )
  • HP Tuners mpvi2
Already in place:
  • Legmaker intake
  • S/C spacers
  • Rear diff brace
Pending/undecided:
  • Throttle body
  • Cooler Plugs???
  • BWoody heat exchanger
  • Clutch
  • D/S
  • N2O
  • Monkey on cocaine in the trunk pushing and screaming "Go Faster" "Go Faster".
There are no specific goals other than having the potential for +200-250hp, which as before, gets me to ~200mph in the Standing Mile.
What am I forgetting?
@jonx96
@16GoManGoHC2 (fuel rail reference)
Do you have a discount code for -Monkey on cocaine in the trunk pushing screaming "Go Faster" "Go Faster??? That's my next mod ....
No, but maybe we can get a Group Buy going on...
:unsure:
:unsure:
I'm definitely in on the group by ......
I dont see how you can see out of the trunk? Is there some periscope device or something?
Plexiglass rear seat delete?
Id for sure do the fic 1200s over 1000s
Even at altitude pushing a car to 200 on e85 I wouldn’t want to be cutting it close on fuel.
You can't go to big on fuel. It will only use what it needs unless it is not there to use
I went id 1300 and the tapped 1.5 which has 295 pumps instead of 285 pumps.
I agree . The 1200's are the way to go ..lots of fuel and easy to tune ..
There was a point in time where bigger injectors caused issues with drivability. But with modern tuning capabilities this isn’t an issue anymore.
MiHiHemi
Parker
2015 Challenger SRT 426
I’m wondering if the aero on these things would ever let us get to 200.
You better get a guard for those big brass ones.
When? Never heard that even in the 90's. My 87 had 800cc in it back in 99
:unsure:
does this have anything to do with human trafficking of a specific ethnic group of illegals..(I may know someone that can help)..o_Oo_Oo_O;)
Regular charger HC was 204.5
No monkeys around?? Can use my ex wife fof free.
707hp gets us to 199mph, obviously in decent DA and enough space.
The guys down at the Kennedy Space Center (2mile course) were coming right up to that.
Not that it's still running, but at the Colorado Mile, if you were running ~750bhp in a Challenger, that got you to ~200mph in the mile.
Was that what you were asking, or something different??
Wow...@ 199...it takes an extra 50 HP to break 200...would lowering the car say 2 inches have any effect @ all:unsure:
