Hey everybody!!!!
Jimmy has his own issues. He's terrified of gators and pythons. This is why he lives on the Tundra.
That's far from the only reason.
Unfortunately it would take several pages to point out all the advantages of living here instead of where you're stuck, and Unholy might get his feeling hurt in the process, too, so I won't.
Especially since he drives a proper 2-door.
Another bully who thinks I'm a snowflake!! 🤣🤣🤣🤣
Thread Starter #103
Fl is America’s 3rd leg
Thinks you are?!? I've been reading your posts for quite some time, pal.
Thread Starter #105
so when’s the wedding @Jimmy N. @DavidKFla and am I invited?
Might have to cancel.
I'm having trouble finding a 2-door limo.
Jilted again. 🥺🥺🥺🥺
Valentines Day. He went to Zales.
Smart move getting married on Valentines Day. We did. He will never forget his anniversary. Lots of reminders. ;-)
You could always get one of the 2 door Hellcats. You would instantly be faster, and look better too. :unsure:
Not following on the look better part:unsure:
Combining days is also 1 less day to have to buy gifts:cool:
Also unholy you will need to address traction issues you will have if you haven't already
Thread Starter #113
Locked out cradle, diff brace, 17” beadlocks with 315/50r17 mickeys
Aad arms make a huge difference on some cars. Camber is different from the factory car to car and being able to get the tires flat on the ground helps a ton. On a stock hellcat you can get away without them. Soon as I put a pulley on my car traction became a huge deal. 315 will help and you may be fine without the arms. I went from 305s to 315 and aad arms at once, night and day difference over what I had
Thread Starter #115
Yep I have a ton of camber, just can’t see spending $1500 on arms. Redeye knuckles are 0 camber, might be more cost effective for me to get those but I just put new hubs/studs on the car, guess I could keep the ones that come with them as spares
Thread Starter #116
With the beadlocks I’m hoping traction won’t be an issue, can sue them down pretty low
Arms are only $700 for camber adjustment
I run 20+ psi in my tires
So I wasn't far off on mine?
You need to run the most you can get away with. Stock on a 305 i ran 22+. Probably could have run 25
