Jared's 2015 Challenger Hellcat Build
It's been a wild couple weeks.
Due to time constraints and the fact that my buddy had a brand new Trackhawk 8HP95 kicking around we decided what we would do is gut the HP95 and put everything in my HP90 case. Easy enough, right? Wrong. There are case differences, and the the front pump/housing/clutch assembly (I'm not a trans guy, I'm not sure what it's called) doesn't fit as it's just a touch larger than the HP90 assembly and gets hung up on the case.
At that point, we had ten days to get the TH400 in and make the event. That day we test fit the trans, found out we had the wrong bellhousing, and got all the parts we needed ordered rush delivery. A few days later, we got back to it with all the parts, decided to go the David Freiburger motto of "don't get it right, just get it running" for the event, and swapped in a Hellcrate harness and PCM.
My tuner was on Vacation so with hours left before we had to leave for the event I just copied my tune over from my pcm to the hellcrate PCM and we got the car up and running. Went out to try the transbrake and bump box and under full throttle the car just closes the throttle blade to 17% and opens up the supercharger bypass.
We ended up deciding to leave the car at the shop and go out and support our friends in the drag and drive, as opposed to bring the car and start fighting with it. I think that was the right call and allowed us to enjoy the event and just hang with friends.
I'll have to figure out what's going on with the car, I'm sure copying the tune right to the hellcrate PCM probably wasn't the best way to go but I didn't have a ton of options at the time. We are swapping manual harnesses into the car and I'll have to get my PCM bench flashed to a manual OS. Eventually I still want to go with a Holley dominator setup but I'm having a hard time opening my wallet for it knowing just how much other stuff the car needs as well. I am definitely playing with fire with the stock bottom end and I don't feel great about it.
Sucks it didn't fit inside the case
Awesome! Thanks Jon! Can’t wait to hear more about this, pretty stoked
Yeah we have all that stuff on the way. Actually, swapping every single harness on the car over to new harnesses. I bought the car already modified and while we were working on it we kept finding wires and stuff cut everywhere we looked, behind every interior panel with other wiring spliced in like shit. The original shop that built the car for the previous owner was a complete hack job, hell the added PWM for the second fuel pump was wrapped in bubble wrap and thrown in a trunk cavity, and all the wiring they did was a mess.
No wonder I've been fighting with this car the past 2 years.
Why you can't trust any shop you don't know personally. Some people just shouldn't work on cars. Sucks they cut all the harnesses. Hack job.
Alright so one is in the wild right now. They have the boxes made they are just waiting on the wiring harness a quick summary from what Rick said
You simpley plug in and run wires to aftermarket shifter for reverse switch and park safety switch.
When it does not see either switch it says drive. When in reverse it goes into reverse on dash . And when in park it says park.
That last parts pretty cool to keep the gear indicator!! 900 is the cost of the box
ETA about 3 weeks
The magic of can bus. Very nice, pretty excited about this. Great work on their part, I know what goes into figuring this out. Wonder if wire harness will have a connection for the engine harness transmission connector and get its power from there since you have can bus, park signal, 5 volt signal and bcm signal all right there.
Jroc
Jroc
Wasaga Beach
Thread Starter #186
ETA about 3 weeks
I appreciate you looking into it. This might be the way to go.
100% the way to go, by the sound of it. wish I could find some videos or something about the car in the wild
Jroc
Jroc
Wasaga Beach
Thread Starter #188
Exactly. Well at least I can get everything completely sorted out and hopefully stop fighting with the car this way. It has definitely been a case of buying someone else's project or buying someone else's problem lol.
Jroc
Jroc
Wasaga Beach
Thread Starter #189
Sounds like it's a can box like we were thinking of making. I'll likely pick one up and do a big write up and video on it when they're available. I bet these will sell like crazy for people doing TH400 swaps and will encourage more people to do them that want one, but don't want to deal with all the computer BS of putting a "dumb" transmission in a "smart" car.
Jroc
Jroc
Wasaga Beach
Thread Starter #190
It's been a while, but I'm back and ready to light more money on fire in preparation for actually having a race season this year.
I spent the tail end of the year driving the car around with the TH400 in it, and quite frankly I hate it. To be fair it never really got a fair chance, its just kind of stabbed in there now, enough to work, but not be happy. I think that along with the fact that my friend specced a 3800 stall, super loose converter hasn't done a whole hell of a lot to make me enjoy the way the car drives.
So that said, I'm going back to an 8HP90.
While putting the TH400 in, we figured out why we had been having so many weird issues with the car. The shop that built it for the previous owner hacked a ton of wiring in the stock harnesses so we have decided to rewire the complete car. I now have new factory engine, chassis, dash, and interior harnesses to put in the car. I have also ordered up an 8.50 weld in cage kit, parachute mount and everything to put a parachute on the car, OST Dyno Demon plus cam kit, new SFI flexplate and arp bolts,and an SHR demon converter. Next up will be to order an MMX 411 stroker kit, and Thitek heads.
The plan is to strip down the car, get all the new harnesses installed, get the cage welded in, parachute mounted, pull the engine apart, get that rebuilt with the stroker kit/cam/heads, stab an 8 speed back in it and get it all tuned and set up. I should have enough fuel system and have the rest of the suspension work etc already done, unless I go to coil overs and take it from there. The idea is to run 8.50s as I don't want to go any further than that cage/chassis wise.
Jroc
Jroc
Wasaga Beach
Thread Starter #191
Got the Thitek Bear heads ordered and some other misc parts. Stroker kit will be ordered soon, I'm between the MMX 411 and 422 kits, from some research it seems as people prefer the 411 on a boosted application so I'll likely go that way, but am open to suggestions if people think otherwise.
What are the best header gaskets for these things? I hate exhaust leaks and have long tubes, I want to make sure to use the right gaskets to have them seal right the first time. The last thing I want to do is be taking those things in and out.
OEM, you won’t have enough clearance to fender with other gaskets. Just installed the 2” HHP kooks and have almost no space. They will seal.
i went with a 426 kit, go big or go home! 😂 in regards to the gaskets, cometic, felpro or stock are all good
Jroc
Jroc
Wasaga Beach
Thread Starter #194
Going to start assembling the 411 tomorrow. What do guys running mid 20 pounds of boost like to set the ring gap to?
What brand crank you use?
I’m at 25 psi of boost on 6.2 Ci, ran as much as 30 lbs of boost, RE cam, through cats, stock heads Thitek ported, 1 7/8 shortie cat forward JBA headers. My ring gap set at .026” and .026, about 7000 miles on engine since build 3 years ago, no issues.
Use 625 head studs or you’ll be lifting heads with time.
Jroc
Jroc
Wasaga Beach
Thread Starter #196
I appreciate it, sounds like you set your ring gap pretty close to what I was thinking, I'll likely go to .026 as well.
It's a Molnar crank, I'm running the MMX 411 stroker kit: MMX 411 stroker. Already got the head studs in the cabinet ready to go.
Jroc
Jroc
Wasaga Beach
Thread Starter #197
Finally made a bunch of progress over the past few weekends. Engine and trans is out, all the wiring is stripped from the engine bay, and the new engine has started going together. Brand new BGE block, all new bolts and sensors, MMX 411 stroker kit, Thitek heads, OST Dyno Demon plus cam, ARP hardware, etc etc. Just waiting on the trans and converter to come in to wrap up the powertrain work. Also waiting on the pre bent cage kit to arrive to strip down the interior, weld that in and swap the interior harness out. I've got the old engine up on Facebook marketplace and am trying not to blow my brains out dealing with all the dreamers lol.
IMG_7957.jpg IMG_7959.jpg IMG_7966.jpg IMG_8071.jpg IMG_8077.jpg IMG_8079.jpg IMG_8080.jpg
Jroc
Jroc
Wasaga Beach
Thread Starter #198
New bullet finally coming together
Finally (after years of your minutia laden posts)...you offer some sage advice..(.P.S.this doesn't mean I like you:giggle::giggle::giggle:;))
