Sign Up! To view all forums and unlock additional cool features
I was thinking about switching my fuel controllers to the triple FPCM that @Speedy! has set up or at least running a second pump full time. Seems safe at the power level I'm at.
Sounds like 60A total when all 3 are at full send...shouldn't be a problem running separate relays, make sure wiring is at least 10ga for the relay to battery, it will support 20A safely per line.
From memory the car is a 20A fuse in the fuse box and I believe the two add-ons are 30A fuses. Those are obviously just limits, would have to look up the amps on the pumps at full tilt to know what they're actually gonna draw.
Just a bit between the cheek and gum, take the gum and throw it away, take the alluminium foil and wrap the fuse with it. Never blow a fuse but your car may burn up.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
