New pb stock boost pump gas
Thread Starter #21
So you have a tune? Is that just to clean up the transmission? Higher rpms and shift points, clean up AFRs? What does the tune change/do? Car is a strong runner with a driver mod too obviously! Great times and way to represent!!!
I originally had it tuned to get rid of Cat Over Temp from the flashing of the pcm during the cat recall. Cleaned up the timing. Added a little here and took some out there. LOL
It also has raised shift points.
Too be clear Saturday Nov 9th was the first time we strayed from pump gas.
The 9.82 was done on E85. The DA was similar to the 9.87 runs on pump gas. The logs show different. I was pulling less air charge and we had a mild cross wind instead of a good tail wind from 2 weeks ago.
