Redeye upgrade
I'm not sure on that. The description in HPT isn't much help. It says "Maximum input shaft torque limit during slip". But I don't know what "slip" is.
Factory 2016 Hellcat is 443 for that value and the factory 2018 Hellcat tune file doesn't even have it, or at least not in the same spot in the cal.
Markp
Fuck Trudeau
Not understanding "max torque limit slip". Does that mean the Demon allows a certain amount of slip up to 959 then has max pressure and the RE does the same up to 339 then adds max pressure? Thanks.
Is this not because the Redeye doesn't have the transrbake?
I thought maybe they delayed max pressure to alleviate driveline shock/ breakage and launch control on the Demon , being it was released as basically a dedicated drag car. Although that would be harder on the clutches. I have read the A8's are basically the same but the Demon has a looser converter. Surprised that even the other settings were the same.
