Race cool down mode
Today 109 in shade on back porch here
Makes sense. You live in Texas. I am talking north central Minnesota on a June day, at more than 20 degrees over average expected temps.
Low of fuckin 80 degrees Sunday night? How screwed up is that? Probably enough humidity to make a Florida day seem mild. Where is that coming from?
Tape
Hell
2021 Redeye
I've never had a problem with it, mine works fine
B
Nicktown
2019 hellcat
Thread Starter #24
So this is what I found to fix my issue.
jgilj Said about a quick disconnect for the battery sense wire. I found this connector on the negative battery terminal. I disconnected it for 10 min and reconnected it. Like magic the problem was gone. Everything works as it should once again. I attached a picture because I didn't think it could be this simple.
Awesome.
Yes. Sucks, but is west texas. Only saving grace, such as it is, is that humidity is usually low.
But then in the evening when the air has been filled with heat energy during the day you will get the formation of tremendous thunderstorms, tornadoes and hail.
Brooksville
I’m glad that worked for you also! These cars and electron’s 😂
