Steering wheel gurus - your help requested and a warning
So, I have a brand of shorts and and pants that have zippers on pockets in the upper thigh area. When I pocket carry (basically all the time) I have discovered that the zipper has scratched the bottom of the steering wheel. I'll post some pics a little later. Anyone run into something like this before? Looks like the steering wheel is painted instead of a solid color body material. Only option to replace the whole unit?
I'll wear my non-zipper bearing shorts and pants from now on.
I would caution against that practice....I believe lewd and lascivious behavior is @ the very least frowned on..and may be illegal even in Texas:oops::censored:
See below. I believe when entering the car the zipper drags across the underside of the bottom wheel center piece. Red Eye Steering Wheel Scratch.jpg
2021 Jeep GC 5.7 TrailHawk
I’d be tempted to find a new steering wheel…and replace the scratched door panel
See below. I believe when entering the car the zipper drags across the underside of the bottom wheel center piece. View attachment 149098
Doesn't your wheel tilt...(I should know but I don't)
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
It's normally at the bottom where you can't see it, I wouldn't worry about it. Or paint it with dull aluminum paint.
Was going to say the same thing.
The steering wheel should be able to tilt.
My 15 did. Both my 16s did and my 19 does.
That would drive me crazy....I would have to replace it
It’s fine. If it bothers you wrap it or take the plastic off and paint it. Leave the steering wheel up when you get out of the car to prevent it going forwards
After almost 10 years of ownership I’ve learned to look past the small imperfections
Whadda mean it looks fine....that would keep me up @ night...:(
Steering wheels aren’t cheap. It’s plastic.
Now a scratch in the paint or dash, that’s a different story
Scratches are scratches...no matter where...they drive me nuts...(but I'm anal bought my toys)
stonewall
Conway
AR
The factory painted it. Just sayen LOL now if the leather got scratched that would make me nuts.
