Lot's of interesting conversation in the thread about pads and rotors. A few excerpts found while researching:
OEM Rotor
- “There is as much energy tied up in a snub from 65 to 60 mph as there is for a whole stop from 35 to zero. So the faster you go, you have a lot more energy in your speed. Since
the brake system takes all that energy and turns it into heat, the heat is transmitted to the rotors. So a bigger rotor has a bigger area for the heat, or more thermal mass. More ability to absorb the heat.”
Erich Heuschele, Manager of SRT® Vehicle Dynamics and Manager of SRT Motorsports Engineering
https://www.moparmagazine.com/2017/08/big-brakes-101/
- Hellcat Widebody for Pike's Peak Hill Climb - The
Brembo brakes are still the same as the factory setup, however, they are now equipped with a set of Pagid RST 1 racing brake pads.
https://moparinsiders.com/dodge-srt-is-taking-the-charger-srt-hellcat-widebody-to-pikes-peak/
- "Comparing the weight of rotor with heat dissipation capacity, it can be concluded that the weight of the rotor increases with increasing heat dissipation capacity."
https://pdfs.semanticscholar.org/aa8d/41f3cf6ed751baa8cf041eb472115ad8e752.pdf
- Pillar Vane Rotor
Demon Performance Rotor (Girodisc)
- The primary purpose of the Girodisc system is to reduce unsprung and overall
vehicle weight. "Reducing the unsprung mass has the additional benefit of improved suspension performance, resulting in enhanced ride and handling."
https://www.girodisc.com/Technical-Info_ep_45.html
- The secondary purpose is to increase the ventilation and cooling capacity of
the brake disc while retaining its original dimensions.
Front Rotor is 6.6lbs less per rotor
- The disc is made from cast iron
- Curved Vane Rotor
- "Decreasing the mass of the disc has a great benefit due to the reduction in rotational inertia. This will allow more of the braking force to be available to decelerate the vehicle, not the disc."
- "If you plan on using stock pads, plan on stock braking performance, but with less overall fade from repeated heat cycles as our rotors cool down much quicker due to the internal design." Demon Performance, Nate
https://medium.com/@Jahee_Campbell/...ion-of-an-automotive-brake-rotor-970008425ccd
http://www.ijresm.com/Vol1Iss7July18/IJRESM_17_13.pdf
Comparison (old stock rotor) (Demon Performance rotor)
New OEM 68184587AE
Old OEM 68184587AD
Demon Performance
RST Pads
