10.15 @ 131, fun trip to the track
Nice time!
Decay
Astoria
OR
2019 widebody Redeye
Correct, no mods. Wheels and tires are Weld S71 17x11 w 315 MT, fronts are Forgestar 18x5 w the 28-6 MT street tire.
Straight Track mode, 93 pump gas.
Have you driven your skinnies on the street much?
I have a 100 mile drive to the track and was wanting to drive on my skinnies and beadlocks.
Both forgestar with the MT Streets
Thread Starter #23
Awesome. I was checking the weather down there and was hoping it would be good.
Glad you got to run in good air. It looks like the humidity wasn't bad for a change.
Up here for good air like that it is cold usually. My last time out it was in the 30's.
So traction on worn tires was interesting at first.😮
Congrats again👍😎
That's what made things so good at HRP, the air was good and the temp was low 50's and sunny. The car made good power and the track took pretty much everything I threw at it.
I won't be seeing conditions like that in TN that's for sure!
Thread Starter #24
1.40 60' ..... that's flat hooking!
Great run, impressive!
Thx Jack. I've been surprised at how much burnout my car requires. If I don't just flat cook the tires it won't 60 good at all.
My thought is that the tire has to do a LOT of the work since the suspension is so stiff on the RE.
Thread Starter #25
That will be a tough time to beat stock, but I have seen a couple people hit 132-133 on 10.2-10.3. Great run!
I was surprised at the low overall mph my car had. I was expecting 133. I don't have an answer for that just yet. If I can get it to mph it'll really run. Lol
Thread Starter #26
Are you using your line lock to cleanoff your tires?
I had a few issues with mine and went to using the footbrake method for that also.
Yes, line lock. It took me a while to get the specifics of the line lock figured out. Once you get it it's pretty easy to use.
I personally can't do a really good, long burnout without it.
Thread Starter #27
I haven't had the skinnies all that long but I have driven it a decent bit with them. I ended up with 50 psi in them to keep them from looking and feeling low.
I intend for them to be my regular street tires from now on.
We had a good outing at the track this past weekend. The car is stock w a wheel change and the easy 150 lbs removed(trunk liner, seats, sway bar). It weighs 4465 on the starting line. Turns out a good starting line and good DA will really wake one of these things up! Lol
Congrats on fun had by all, and thanks for posting. Keep up the good work!
Havre de grace
19 Redeye
What tire pressure in the rear ?
Thread Starter #30
Markp
Fuck Trudeau
Your 60 is incredible and so is your ET just wondering why your mph is so low for the ET? I would think you would be in the 134-136 range
Thread Starter #32
You're not the only one wondering that. Lol
It never feels like it lays over, it just doesn't mph great. No clue.
Awesome 👏
I guess it could be the back tires, or the tire size effecting MPH... but even a 6.4 in the 1/8th should just about be a 10.0...
Markp
Fuck Trudeau
Ya that’s a little strange because if you look at my PB you had me crushed and should have out mph me. Also you have skinnies and I don’t which should have helped your mph I would think. I will tell you what if your car is pulling power at the top and your running times like this you have a 9.99 in your car if you can get it figured out. Maybe a gust of wind at the end of the track slowed you down? What was your tire pressure at?
I don’t understand why everyone looks at mph , when the et is what matters I only care about 🤔I’ve seen them stock demons race and they have quicker 60s and quicker 8ths and are always slower on the big end
TEXAS REDEYE
PASADENA
2019 HELLCAT RED EYE
Just curious, did you run your Redeye at the Legion of Demons rental? Friday would've been test and tune, most of Saturday would've been rained out, leaving Sunday for Legion of Demons only.
Houston Raceway Park. It turns out there is a place outside Canada and New Jersey that has great DA! Who knew? Lol
Congrats , nice pass , well done !
I was at HRP the weekend b4 you, & we had low DA but high humidity. My best was 10.24 @ 135 , stock boost HC.
Decay
Astoria
OR
My Scat worked a little better when I put everything in track except the suspension.
Allowed the weight transfer to the rear.
That was my custom setup.
Markp
Fuck Trudeau
I know what your saying but I have always thought that mph kinda shows the full potential of the cars ET? For instance we all knew how fast hpindy's car was because of his mph. Once he figured out his 60 the mph went up a little bit but the ET went down a lot. High mph that doesn't match ET shows your leaving some time on your 60. Does that make sense ? I don't think this is the OP's problem though because he has the best stock 60 from a bone stock cat with drag pack.
